I've never worked in Raw or Log, but as I understand it with skill in color correction you can make it look like what ever you want. Correct? So really this becomes the camera that every cinematographer can afford to own and can be made to work in most any situation. This will be more than good enough to use as A cam, no question, but there will be a lot of situations where something else is specked.
I assume once this is out in the wild people will be busy making look-up tables to match the look of the other systems currently popular. Is this a reasonable assumption. For example, something like the FS700 is going to be a hit out the door because of the slow-mo, but it won't be raw right away, so if you wanted to shoot real time with the Blackmagic, you'd correct to the look of the Sony, and not the other way.
