Do not buy a 4k monitor or TV until HDMI 2.0 comes out this year!
Robert Bentley
I had no idea about HDMI 2.0. Currently they are finalizing the details on it and it is supposed to come out this year. Apparently this is why some of the old 4k TVs are starting to rapidly drop in price, to unload them. The Seiki 4k TV is now going for around $965.99 on Amazon...
http://www.amazon.com/Seiki-Digital-SE50UY04-50-Inch-120Hz/dp/B00BXF7I9M
Here is a great article explaining HDMI 2.0..
http://www.digitaltrends.com/home-theater/hdmi-2-0-explained/
HIGHLIGHTS OF THE ARTICLE:
"The first crop of 4K Ultra HD TVs from Sony, Samsung, LG and Toshiba have HDMI 1.4 ports that can feed full resolution 2160p (4096 x 2160) Ultra HD signals, but there’s a catch — they can only do so at 24 or 30 frames per LG 84 inch 4K TVsecond. That’s works fine for movies, but is of no use for gaming and gaming and only some TV broadcasts, which require 50 or 60 fps."
"Another thing worth noting is that the current HDMI 1.4 limit of 24 fps in 4K is also in 8-bit color. Ultra HD is expected to bump that up to 10 or 12-bit. With the faster 60 fps rate, twice the data throughput will be needed to push all that — something HDMI 1.4 simply cannot do."
So to some up, you'll need HDMI 2.0 to get the 10 to 12 bit color if you want to grade your footage properly and to future proof yourself a bit with dealing with higher fps.
Well, there are other standards that support higher frame rates, like DisplayPort 1.2 supports 4k60p.
