Anyone know about DMX cables? (The 5pin XLR cables used for controlling lights.)
I use a Datavideo switcher (HS-2000) that uses those cables for the headsets / tally.
We ordered a few Hosa 5 pin XLR cables from B&H, but they only have 3 wires in them. (See attached photo.)
Obviously they don't work with the switcher as the switcher needs 5 wires for the headsets / tally. At a shoot with long cable runs I borrowed a DMX cable on a multi cam shoot from an AV / lighting tech & everything worked perfectly.
This seems like they're bad cables. Unless, does DMX use a 5 pin connector, but only 3 wires? It doesn't seem to make sense that you'd have empty pins with no wires connected to them.
