Carlos_E._Martinez
OK. Here's the challenge: how about DIYing a softbox for some open heads we might have?
Last week I started thinking about it. The main barriers to cross are the speedring and the flexible metal bars inside the dome.
The Chimera I used last Saturday, fitting an open Arri 650 head, had a square aluminum frame that entered on the holders up front.
It had four holes, where you forced in the four metal bars holding the dome.
The speedring must be metal. Wood or acrylic wouldn't stand much use or the heat.
So we would have to start with a solid aluminum plate, about 1cm thick, to make the frame from. I wonder who would cut that frame for me, externally and internally.
Then come the elastic metal bars. They work very much like on an umbrella. The Chimera's were about 4mm thick, if I remember well, with a thicker point where it enters the ring. The assembly has to be taut, so as to stay as a dome.
Which metal would have that elastic characteristic escapes my mind. It has to be thin, straight and ellastic, so the tension beween the external dome and the force on the speedring keeps the shape.
Suggestions? Ideas for the two problems?
