DIY Resolution charts - any tips and hints?
thabo
I have downloaded a printable chart from here - http://www.graphics.cornell.edu/~westin/misc/res-chart.html and printed it out on my laser printer. I'm aware that it's best to buy one but this is the DIY thread right! I profess to know nothing about how to use it so am looking for some tips.
I basically wanted to try to figure out the resolution of a crappy little kodak playful, a flip like camera I bought for $69 off Amazon. I stuck the chart to the wall and lit it as best I could. I then did a test with my HMC40 and compared the results to Barry's test found here - http://dvxuser.com/barry/HMC40-res.jpg
I think my chart HMC40 chart looks similar to Barry's but I'm puzzled as to how one can come up with an absolute resolution number? I also didn't print the entire chart out as it would not of fit on the letter paper from my printer; if I did I figured it would no be correct as it'd not be 100% of the original size. Of course the little Kodak had no manual controls so I just pointed it at the chart and hoped for the best but the I fiddled with the HMC40 a little, F3, no gain.
So any hints on how this DIY and admittedly inferior method might give someone decent results?
Attached are my Kodak playful and HMC40 results.
Not sure what the DIY aspect of this is, there are some tutorials and charts online for resolution testing. But for a DIY project you could learn PostScript and create your own res charts, it's actually a pretty easy language to master. If you know a programming language you can even do some pretty complicated repeating patterns. A good project might be generation of a sinusoidal zone plate for testing resolution of video cameras.
