looks good, and funny. Where did you get the angle iron and how much. I have some long stuff i could cut, but would like to weigh that versus pre cut.
The angle iron bits I found in my local hardware store, they were about €1.40 each and came with pre made holes (had to make the holes slightly bigger with a drill though, but having them there already saved time on measuring exactly where they should be).
Problem that I encountered was that I didnt tighten the wheels tight enough the first time so they came loose after a while. So if you have a one long iron bar it might be difficult to tighten the wheels if they go loose...
