DIY Kino Flo 4-light set
Thanks. No flicker because the ballasts are electronic with an operating frequency above 42Khz as opposed to magnetic ballasts which operate at the line frequency (50/60 Hz).
Nice job!!
And thanks for the spreadsheet. I miss the "insides" of the ballast though, any hint would be appreciated.
Nice job!! And thanks for the spreadsheet. I miss the "insides" of the ballast though, any hint would be appreciated.
Here's some more pictures which includes a view inside the box.
https://plus.google.com/u/0/photos/113053184636543874722/albums/5792948460355580017
Each fixture contains two 3-light ballasts, plenty of black & white AC wire (for the ballast box) and 1000V blue & red wire (for wiring the new fixtures). I still had to get some more 600V red & green wire to finish the fixtures. Let me know if you have any more questions.
You're welcome. I wanted to share a mod I did. I added side pieces to the barn doors so it both blocks spillage and strengthens the long doors so I can attach a diffuser or grid. Here's a picture. More pics on my G+ page showing the light control. Cheers
I don't have a meter yet so I can't give hard readings. Using all 4 fixtures for a headshot with the subject 2' away, the D800 exposure is right where I want it to be at iso 100, f2.8 and shutter at 1/200th.
I wanted a wider catch light and also to reduce/eliminate the small gaps between bulbs and fixtures that look like black shadows in the subject's eyes. A diffuser may do that. I'll do some shots tomorrow.
