skategriggs
So Im always looking for ways to build a image flipping module and i've been wondering whether an optic prism could be used to flip the image. So i did some research and found some interesting stuff. And it looks like there are several prisms out there that can easily rotate the image, even some in a more space saving way that appears to be a better method than the bulky flip modules that letus, brevis and other 35mm adapter companies use.
So anyway here is what I have found, and Im wondering if any of you know whether this could actually work.
Dove Prisms:
These prisms will rotate the image straight through and it looks like you could place them right behind the ground glass where empty spacing is usually located on DIY adapters.
I found a company that builds these with a face up to 40mm which would be ideal to cover the area of a 35mm screen, correct?
What do you guys think of this? could it work?
Pechan Prism:
Same function as the Dove prism, just a different design. I also found this being sold with a face size of 40-50mm, again I think this would be ideal. Its also said that the Pechan Prism has a wider field of view than the Dove Prism.
What do you think?
Porro-abbe Prism:
Same function, and again available in large dimensions. Seems like this one could be a little more bulky and harder to incorporate into a 35mm adapter system, but im not sure.
What do you think?
So what do you guys think? Any knowledge on these prisms and whether it could work? Which one would be the lightest, most compact, and provide best image if it could indeed work?
Thanks for the help! I hope to nail this issue, but arn't we all? haha, and Im sure im not the only one who has investigated this, so sorry if this is a double post, but help me out if you can!
Dove Prisms:
Pechan Prism:
What do you think?
Porro-abbe Prism:
What do you think?
