The Huco gearboxes are both available from RS Components.
The one with plastic gears is RS stock number 748-443 and is £11.05 +VAT, and the one with the metal gears is RS stock number 748-437 and is £19.01+ VAT.
Both have nominal shaft diameter of 4.0mm(3.988mm) and are designed for an interference fit for 3.9mm gears etc.
You can order by mail from RS components, although I think their P& P can be a bit pricey. Most big cities have a branch you can visit and buy over the counter.
Here is the link for the metal geared version, it has all the specs available, as it is identical to the plastic gear version the specs will apply to the other one as well.
