robertwerden
The new wave of 35 mm adapters use a flip unit to right the image in your view finder. The method of doing this is by using a Porro Prism. Porro prisms are found in binoculars of the old days. Todays newer binoculars use Roof prisms, which eliminate the need for a 90 degree zig zag in line of sight.
So would it not be a better idea to hack into a monocular that uses a roof prism and simply remove the prime lens from the monocular as well as replace the small achromat with a larger one?
Here are some photos to better show my thought process here.
As you can see the Roof prism side (left) shows the lenses in the same order as a 35 mm adapter.
In order going from top of image to bottom
1. Eyepiece lense. (remove because your camera lens would replace it)
2. Achromat (remove and replace with one that is the same size as you would normally get with a 35 mm adapter such as 72mm)
3. Roof Prism (performs the image flip)
4. The focusing screen would replace the next lens.
5. Your Nikon or other Prime lens would replace the objective lens.
Tell me what you think of this type of set up.
