Diy HMI Ballast Problems
I am working on some diy 150w HMI fresnels based off of Cool Light's tutorial in his blog. What I have is an old Kliegl 650w fresnel, a g12 ceramic socket, a cool lights 150w hmi 5600k bulb, and two different ballasts.
The first ballast is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=120257730827
Its spec sheet says it is 120/240v (V), 175 (W), 1.36/0.68 (A). The problem with this ballast is it causes a flicker in the bulb with a color change each time it flickers. It isnt like a fluorescent flicker, it creates more of a candle flicker-like the filliment is fluctuating inside the bulb. I thought maybe the bulb needed to be worked in so I let it run for 3hours and the flicker continued (I have only ever rented HMI, so I have never had to work in a bulb.) I figured it must be caused by the slight over wattage in the ballast 175ballast-150bulb, even though they say it can handle a 150w bulb.
The second ballast is: http://www.ballastwise.com/item.asp?PID=126&FID=17&level=1. Its spec sheet says it is 120 (V), 160 (W), 1.48 (A). The problem with this ballast is that it won't fire up. I think it might not be a pulse start ballast. If that is the case where can I get a pulse start for this ballast?
Anyone got any ideas as to what I am doing wrong, or any place to find the right ballast.
You do have to match exactly the wattage in metal halide or it won't work. 150 to 150, 175 to 175, etc. Your second ballast may actually be a sodium vapor type and not suited to our bulb. Contact me at richard@coollights.biz and perhaps we can hook you up with a ballast.
Very nice work. Are you going to post other picture or instruction on how to do this type of modifications? I have an older par lamp and I would like to try something of this magnitude.
