natxbrotha
I'm trying to figure out a solution for the 7 battery chargers I have... all of them but one has the flip out wall plug and no cord.
So here's the challenge: how would you design you own charging station to accommodate 7 chargers?
My first thought was using one of these:
They usually have 2 plugs on the front and one on the back. If I daisy chained a few of these together I could make an "Octopus" charging thingy that hangs.
CONS:
The 1st problem is there would be a TON of extra AC cable that's not needed.
The 2nd problem is you can only get 3 chargers per cable.
PROS: Cheap.
Here are the size chargers I'm primarily working with:
What are some of your ideas?
CONS:
PROS: Cheap.
