DIY battery Powered Ring Light
Harry Pallenberg
I’ve wanted a battery powered ring light - but most are either WAY too much money or they are built for DSLRs and are too small. I was at Pep Boys (auto parts) and saw that they had these little battery powered LED lights and my quest to build a ring light was on.
I realized I should look elsewhere, so I went to FRY’S Electronics and found a better LED light - the Trend Sources Group 24 LED 2 pack for $19.99. They are basically 24 LED lights in a rubber casing that can be cut after 3, 6, 9, 12, 15, 18 or 21 LEDs to adjust the size. This is great because no matter what size hood you have you can cut this to the size you need.
I started by chaining two of 9V batteries together to power them and discovered that one 9V worked but was much dimmer... hmmm... built in dual brightness settings.
My soldering skills are about zero and I was starting to cut the wires shorter and shorter as I tried different things so I stopped into a Radio Shack to see what they had as far as ways to connect wires (I went with crimp connectors)... but more importantly I found the ENERCELL AC to DC Adapter with Battery Backup for $60 bucks. This thing has multi volt settings (3, 4.5, 5, 6, 7.5, 9 and 12) so I can still get my 9 vs 12 volt dimming, it can power up to 15 watts and best of all a built in battery if there was no AC outlet around.
So now I could run the lights with AC power or from the battery pack. The unit also can charge devices via a USB port as an added bonus. On my first test it ran both light strips for over 2.5 hours and it only takes 2.5 hours to charge - so if you bought 2 you could go all day. It comes with your choice of plug adapters (the white thing on the end of the cord) and Radio Shack has all you need to connect the other end to the LED wires.
I used a large rubber-band to hold it on the lens hood for now. I’m still working on this part and have ordered an extra hood so I can experiment. I think I’ll go with some white camera tape first to work sort of like umbrella (there is a lot of light leak out the back and sides), then black tape over it all so it looks better, matches the color of the lens hood and does not get dirty.
So far in testing it is pretty good. Always do a white balance. I’m thinking of adding another 2 strands to make it brighter. The ‘famed’ ring look in the eyes can only be attained by being REALLY close to the lens and it is more of a rounded rectangle - but from a distance it throws a great little catch light / twinkle in the eye. In a totally dark room form about 4 feet away with 5db gain I was able to get a usable image. Closer was obviously even better. The LEDs are not painfully bright to look at, especially if the subject is looking slightly off center. I'll post some video soon.
The problem with that one is it is sooo small - basically goes around a shotgun and not the actual lens - so it is sorta like any camera mounted light (not dead center and too small to give that ring light look).
I have now found a better (longer / brighter / cheaper / less wire splicing to get more LEDs) led light. It is 96 LEDs long for $23 + shipping vs $20 for 48 LEDs:
http://www.superbrightleds.com/cgi-...egory=BARS&Page2Disp=/specs/WFLB96.htm#photos
So your cost (not my trial & error) would be $23 for LED, $60 for Enercel (which I also used to charge my iPhone!) and about $4 at Radio Shack for a connector. Throw in a few bucks for tax or shipping and you are just a tad over $100.
Pic of the 96 LED installed...
Pretty cool! :thumbsup:
I'd like to see how it performs in an ambient-lit room (i.e. overhead fluorescents, for instance...) when used as a fill light in an ENG application; not just as a spelunker key light in an otherwise pitch dark room.
