starcentral
Over in the Lighting section there is a nice thread on the Alzo 3000 which so far seems to output about f8 at 10 feet with 640 ISO. This is pretty good as a broad light source and once combined with a light modifier (softbox, etc..) seems to still have enough output power to render it "useful".
The completed units sells for $325 and up depending on where you buy it. ie. Alzo, Amazon, ebay,... and specs say they output about 9000 LUX @ 1 meter. Users have already confirmed the output is quite high, which is great. CRI to be unconfirmed but data sheets I have been reading show very low CRI's (around 70) for 5600k lights, but much higher CRI (around 90) for 2700k LEDs.
Considering the actual parts themselves are in-expensive it got me to thinking about a DIY project using these high power output LEDs, either in single or even QUAD configuration. Perhaps mounting one or two inside an old ARRISoft 1k metal chassis I had kicking around so I could have some easy 5600k soft light at my disposal.
100w LED's need anywhere between 20-30 volts and a constant current typically around 3.5 AMPS to operate. 100w LED's can be purchased from between $12-$60 depending on quality, and a dc-to-dc convertor with minimal electronic components added can be converted from a constant voltage power supply to a constant current supply needed to drive the LEDs. Used these dc-to-dc convertors can be purchased from between $12-$30.
Anyone play around with these on their own yet? Looks like something I might try.
