And menu, I don't think your example is good at all. If an actor is having family problems, firing them is not going to make them a better actor, it's not going to increase the chances of your film's success, and it certainly won't want to make other actors or crew work with you.
In your example, you don't have to help the actor with their "problems," you need to get aperformane out of them. You figure out how to turn that emotion into what's needed on screen. If it's just absolutely not possible at this time, then picking up another actor is not the worst case scenario, but you don't want to just fire somebody. You have an entire crew to deal with and if you just start firing people because their parents died, you're not going to get a good performance. Instead, I would work it out w/ the actor that, if they really want to do the film and need more time, reschedule the shoots to work them in later. If this isn't possible, then mutually (and amicably) part ways, with the knowledge that you two will work together again in the future.
I strongly disagree with Jade8472, i think an employer has an obligation to care for his employees when the fall sick or are otherwise troubled. Where I live it is the law .
On the subject of directing and scheduling, I think you all know that the ADs are in charge of that side of things.
Otherwise, on smaller crewed projects, intelligent scheduling would be much more a factor than whether or not someone is pushy or not.
Let's not forget that when the show is done, nobody cares how long it took to shoot, or how fast it was edited, or how much it cost or didn't cost.
A director doesn't have to be bossy, or pushy, or even terribly articulate.
The director just has to have a clear vision of the show and the determination to see it through to the end,
which, depending on the strength of this or her vision, will bear more or less resemblance to the intended show. (Oh, and it helps to have actors to work with who understand your vision, and like to work with you, if you have actors in your film.)
If there's any strength that all directors share, it's in that sense.
