marvinhello
Hi there I recently noticed something interesting with digital audio meter, when I play the same audio file in Foobar 2000 and Adobe Audition, these two programme give me different dBFS readings, if the audio peaks in Foobar around -20dBFS, then it's around -12dBFS in Adobe Audition, they both have 60dB scale and I've tried 16bit and 24bit file with various sample rate, the difference still exists.
here is another question, in Audition I saw an option of setting playback sample rate, it could be set as high as 192kHz, is there any advantage/disadvantage of setting this to 192? or should I stick to default 44.1kHz? Also in Windows playback devices properties, there is a setting about sample rate in shared mode, do I set this to highest 24/192 as well? thanks:cheesy:
