Digibeta hell... -;( Sony DVW 500p + Decklink
gunleik
Hi.
Struggeling to lay back some work to digibeta through the DVW 500P and with a decklink card.
Two problems.
1.
Striping the tapes.
When I stripe them from the deck, the TC suddenly goes haywire and jumps all over the place
when I try to black them from the "edit to tape" window, it looks better, except from the fact that I cannot get the TC to start where I want (usually it starts around 15-20-23'ish hours somewhere. I need it to be at
00:00:00:00
Or more ideally:
I'd like to start at 23:58:00:00 and insert @ 00:00:00:00
I've set the device control preset to LTC + VITC and the pre-roll to 10 secs (I've tried up to 30 secs)
My tapes are all new btw.
Finally I managed to stripe 6 minutes (which is just about enough), but then I get the
"Unable to lock servo on deck" message.
I would happily read the bleeding manual, if the rental house hadn't decided that the manual was not to come with the deck...
Anywhere I can DL it as a pdf?
I have upgraded the declink software, with the exact same symtoms as the result.
Any ideas appreciated!
I can also be reached privately at gunleik (at) vulture (dot) no
Cheers!
Gunleik
