Different frame rate clips in a single project?.
booggerg
Carbonite Member
I started working on my 1st wedding in Vegas. I had a normal 1 CCD cam as a secodnary balconey cam. I started the proejct with the 24p setting and captured everything from my DVX and it looks great on the NTSC monitor. However, the 60i footage from my other cam is rather jerky and have to be rendered. So I'm deciding to go back to the normal 29.97, lower field setting. However, in doing so, the DVX's 24p footage will have to be rendered. So my question is that when made all the captures in 24p mode, did it actually only capture 24 frames/sec? I thought Vegas is just doing reverse pulldown on the fly. Is there anyway to use my DVX footage in a 29.97 interlaced project w/o rerendering each clip?
Re: Different frame rate clips in a single project
Sure you can! Import the clip into a 29.97 timeline, and go to the preferences and find the option for "automatically remove pulldown from 24P clips" (or something like that). Make sure that's de-selected, and your 24P clip will play in the 29.97 timeline with no rendering necessary.
