Different Apps See Differing Amounts of P2 Clips??
puredrifting
Major Contributor
Hi:
Did a shoot yesterday on my HVX-200. All footage shot at 720 24PN as I usually do. No differing frame rates, nothing unusual. Shoot went great, first high profile client project with the Letus package, footage looked great. I dumped all cards to my MBP and a FW bus powered drive as we were shooting and as I have hundreds of times before. At the end of the shoot, cloned my drive to client's drive, she took it to her office and was loading the material into FCP 5.1.4.
We shot five P2 cards worth of material. She is able to load all of the material fine into FCP 5.1.4 except for a few clips. Then we enter the Twilight Zone. She is an experienced editor and we just completed another big project on P2 so she knows the workflow.
She is in the P2 import dialogue in FCP and highlights all of the clips and presses the add to queue button. When FCP finished loading the clips, about half of the clips came in successfully, the other half (about five of them) do not come in, they show up in the queue with a red exclamation point on them and the cue status just says, "idle". She deletes them from the conversion queue and re-loads them. Same result.
She calls me for advice and I bring up my clone of her drive of my G5 here, which I also keep 5.1.4 on just so I have compatability with cient's like her that are on 5.1.4. I get the same result on my system. Strange, I have never run into this in thousands of P2 cards shot and edited over the past two and half years. We both discover that if we load a single clip at a time into the queue, rather than all of them, sometimes FCP works and brings it in and sometimes it doesn't. Weird, inconsistent behavior. In going through this trial and error way of loading the clips, she finally gets almost all of the clips captured. All of the clips except two. Both of them show up in the capture window with no TC and duration, they just both say, "spanned". Very strange, I have never ran into this before either. Fortunately, when loaded into P2 Log Pro, the missing "spanned" clip plays back fine so I export it to an FCP XML/QT and deliver the missing two clips to the her so all is well.
I decide to examine the clips in some other applications so I bring up the clips in P2CMS. All of the clips show up and play fine, so I know that the media is there and is not corrupt. Just for fun, I bring up the clips in P2LogPro. Okay, the first card that had four clips on it with one spanned, it shows up in P2 Log Pro with five clips. It showed up in FCP and P2CMS with four. I check and the clip that said "spanned" ends at 02:37:19:04 and the TC on the next clip that wasn't there in the other two programs begins at 02:37:19:04. It ends at the same frame as the main clip did in FCP and P2CMS. So overall duration is identical, its just that for some reason, FCP and P2CMS see the clips as incomplete and for some reason, P2 Log Pro sees them as complete and can play them back fine.
Also, just to try something else, I bring up the same drive on my MBP with Final Cut 6.01 and while the same amount of clips shows up (four), the clips that showed up as spanned in FCP 5.1.4 with no TC or duration shows up in FCP 6.01 as "spanned" but it has TC and a duration. Just to check, I capture and transfer it, it plays back fine.
I would really value some input on what the heck is going on here because I am puzzled
Equipment used:
Client's system - Old G5, not sure of speed but it's something like a dual 1.8GHz, plenty of RAM, QT 7.3.1, FCP 5.1.4, OS is Tiger, not sure of exact version, but I think it's something like 10.4
My G5 systems - The system that the spanned clips would not load on - Dual 2.3GHz G5, 4GB RAM, FCP 5.1.4, QT 7.2, OS 10.3.9
My MBP - The system that the spanned clips would load on - 2.2GHz Core 2 Duo , 4GB RAM, FCP 6.0.1, QT 7.2 OS 10.4.1
Camera - HVX-200, bought March 2007, has never had any firmware update or anything else, three 8GB P2 cards, one 16GB P2 card. I have shot thousands of P2 cards of material with this setup, have never experienced anything weird like this. That's what is so strange about this whole experience, all of the gear used is stable, proven and none of it has anything weird with it for any P2 projects.
1. Why would clips no load into FCP in a group but would load in (mostly) one at a time? I usually just highlight all clips, add to queue and they all load. With this shoot, all of that seemed to have changed
2. Usually you can preview the footage on the P2 capture window in 5.1.4 or in the Log and Transfer window in 6.0.1. In 5.1.4, with the media from this shoot (all five cards, even the ones that imported perfectly) all you got was a blank, black screen and in 6.01, you get a gray screen saying, "Playback from this format is not supported"?? Why would that be? I have always been able to see playback from P2 footage in any FCP P2 capture or log and transfer window. Once imported, the clips playback fine in the viewer but not in the capture window.
3. Why would FCP and P2CMS only see four clips where P2 Log Pro would see five? Same overall duration but differing amount of clips.
4. Why would the same P2 card register a clip as "spanned" with no TC and no duration in FCP 5.1.4 but register the same clip as "spanned" but with TC and duration in FCP 6.0.1? As stated, would not import in 5.1.4, imports fine in 6.0.1???
Luckily this shoot went well and with some hard detective work, I was able to bail out the client but I am really concerned that this doesn't happen again. I know P2, the HVX and FCP very well and all of their weirdness has me stumped, I have never seen anything like. We are on QT 7.2 so I know it's not the dreaded DRMS issues that have plagued a lot of FCP users recently. We have successfully used all three of these systems a LOT of P2 recently and we have not changed or updated anything in the chain so I am perplexed as to what the cause is.
Your ideas and suggestions are appreciated.
Dan
I cannot answer all your questions, except to reiterate that the P2 import window in FCP is not something I would ever rely on. I would use anything other than that -- Raylight, HD Log, anything. But that's just me. I have seen this same question asked dozens of times across the various forums, and the only answer seems to be "upgrade your software."
FCP's import window has been broken, fixed, broken again, and fixed again. I don't trust it at all. You could try Raylight and see if it makes all the questionable behavior go away -- it usually does.
As for this question:
Probably a spanned clip? Even if it's spanned on the same card (a five-minute 1080 clip, or an 11-minute 720pN clip?) then P2cmS will reassemble the pieces into one contiguous clip -- but it will still exist on the card as separate chunks. Perhaps P2 Log doesn't automatically reassemble those? Don't know.
Hi Barry:
I was hoping that you would respond, thanks!
Hmm...interesting. I have heard that, but was always happy that 5.1.4 had been so stable and reliable for P2 for me. I would estimate I have used it for approximately 1,500 P2 cards worth of material without missing a step. Curiously, I had major issues getting the Raylight plug-in to work correctly on a project last year.
I do have P2 Log Pro, perhaps I should just use that and export the XML/QTs to FCP instead? I guess I was just freaked out beause I have used FCP 5.1.4 for so long for so many P2 cards without a problem, it struck me unawares when it finally acted up. Who knows why? FWIW, I had better luck with my MBP with FCP 6.02 on it. I have to keep 5.1.4 on my editing G5 with the Kona because I have two clients who I edit for that also edit and they both have 5.1.4 systems so I am kind of stuck with it until they upgrade.
Plus they keep re-naming it, it was P2 import, now its Log & Transfer, who knows what they will call it next?
Both clips that misbehaved were spanned because they were 720 24PN and were over 11 minutes long. I am going to speak with Imagine this week to find out how and why P2 Log Pro treats spanned clips and I will report back, just so you know.
Yeah, as much as I like FCP, it has it's issues. It just seemed weird that on this shoot yesterday, everything that has worked like clockwork for so long just went haywire.
Thanks for your thoughts.
Dan
And that's exactly my problem with it. We've got dozens of threads of similar unpredictable behavior. The only commonality I've ever seen even proposed was the idea that some people weren't selecting the "remove pulldown" checkbox, but -- you're well experienced, you're shooting pN, and it still happened to you. That's what makes me not trust it -- even though the vast majority of HVX/P2 users are using it. And it works very well the vast majority of the time.
HD Log also has Raylight-style functionality where it lets you bypass the import window completely, have you tried that?
Also, P2CMS can let you bypass it and drag the MXF files directly to the timeline, but you have to manually import and sync the audio. I don't know if that'd be worth it to you to get you past those few clips that failed to import?
I'd advise moving up to FCP 6.02 and you'll find many of this will be solved automatically.
Noah
