drubynum said:I'm still ""in the dark" here. My question is, if the opening and closing of the curtain (shutter) creates a frame, then if your shutter speed is 250, why doesn't that mean you're shooting at 250 frames per second? Or does it mean that each of the 25 frames at 25P are exposed for 1/10th of a second (25/250)?
drubynum said:How is it that a faster shutter speed produces smoother motion if we're seeing a shorter exposure time per frame?
Hear, hear, Silver Wolf. Sometimes I think I'm the only writer in the English language who insists on talking about shutter time or setting, or exposure time and never about shutter speed (unless I mean the actual physical speed of travel of a physical curtain or blind).SilverWolf said:Just think shutter speed = Exposure time for each frame.
David Jimerson said:It's the recording time per frame. At a shutter speed of 1/250, the light on the chips is read for 1/250th of a second every frame. So, at a frame rate of 24, 24 pictures are taken per second, and the exposure time of each picture is 1/250th of a second.
Sepand said:Shutter Speed was the one thing that I never thought could confuse me...
So, at a shutter speed of 1/4, exposure of each frame is 1/4 of a second?
That means we're shooting 6 fps...?
I mean we have only 6 different frames each is repeated 4 times continuously?
Barry_Green said:Yes.
(but if you're shooting in interlaced mode on an interlaced camera, understand that you'd have only four fields; shooting with a shutter speed slower than the field rate on an interlaced camera results in only a single field being used so it means your footage drops to half-resolution. With a progressive camera that doesn't happen.)
You will have 24 frames, but each frame will be duplicated six times. You'll have four distinct images. You can't expose a frame for longer than its duration, obviously; if you want 24 individual discrete different frames then you cannot under any circumstances have a shutter that's open longer than 1/24 of a second.USLatinContent said:What?!? Woooow, Yes? I am so confused now!
If we shoot 24fps with a 1/4 exposure won't we have 24 frames were each recorded 0.25 seconds of the light comming in..? that makes 6 frames worth of exposure but they are still 24 individual frames right?
There is no physical difference. Using the shutter angle on the HVX allows you to specify the exposure time in extremely precise increments, and the shutter angle tracks exposure time with the frame rate. But at 720/24p, 180 degrees yields 1/48 exposure, 90 degrees would yield 1/96 exposure.MDP 16mm said:I am familiar with the shutter speed and how it works. Not to hijack the thread or anything but what is the difference between shutter speeds and shutter angles on the HVX. On my SR3 super 16 camera the shutter angle is a physical adjustment. Is there really a difference between shooting at a 48th of a second or 90 degrees on the shutter angle if you are using 720 24p default settings.
Thanks, Mike
