Snapper123
Hey guys, I'm really looking for tips on how to get a depth of field where the focus plane is quite wide without degrading the quality of that plane or changing the framing of your shot. With my 50mm lens, which is my favorite lens to use, the biggest problem I have is not exactly that the depth of field is extreme and very thick looking at low apertures, but that the sharp focus plane is paper thin in any scenarios like interview shots. I've come across many situations where I want a close-up shot of the subject, yet while I don't mind the thick texture of the blur, it's more that I wish for the sharpness plane to be deeper than a couple centimeters. The focus plane really doesn't seem to widen until you close the aperture down to the double digits range, which is impossible to use indoors. And if you back up a bit with the same lens, the focus plane gets a bit wider, but it all washes out in quality and then you're also left with not having the framing that you desire.
So what would help me in the 1.8-3.5 aperture ranges? Having a wider angle lens and getting closer to the subject? Using a zoom range lens at a focal length like 75mm or 100mm and standing farther away from the subject? The main point is that I wish there were some extra number that extended the depth of the focus plane without weakening the surrounding blur or having to use closed apertures - like image you're shooting at 1.8 and you had some sort of wedge that pushed the two thick slabs of bokeh farther apart, but otherwise left the aperture and bokeh strength alone. Are there any ways to do this even if not fully? And just another point to keep in mind is that I'm really talking about doing this in the 1.8-3.5 range, it's not that I care anything for extreme bokeh or blur, it's just that as it is, I use prime lens apertures more than anything else I can think of.
