Denecke TC-1 Time Code Reader with PAL
lutnik
Puzzling question for the audio gurus.
Would a Denecke TC-1 Time Code Reader work in the PAL land?
From specs, it is said to generate 60Hz sync pulse from either 24 or 30fps time code.
I assume that wouldn't work with 25fps/50Hz PAL stuff. Am I correct? Is there any work around or you have to buy PAL-specific time code equipment?
Tks
Lutnik
why do you need reader only ?
very limitting ,
you will not be able to jam it and use only with cable or reciever
as it only the reader it would read any tc which comes to the salte .
