DC Brandon
Not sure if this belongs in this forum, but here goes:
I am about to jump into TV commercials here in our local Canadian market and was given the delivery specs for local broadcast. I have a few questions I am hoping senior members can answer for me.
They sent me a form that says the following:
HD creative must include SD down convert aspect ratio
Framerate: 1080i 59.94
HD Audio Info: CH 1& 2 - left / right
DV on track 7 if available
Discrete: 1-LF 2-RF 3-C 4-LFE 5-Left Surround 6-Right Surround 7&8- DV 9&10-Stereo
(7&8 can be stereo if no DV track)
Must have Audio Metadata
We don't accept Dolby E
I understand that I must deliver the commercial with a resolution of 1080i and at a framerate of 59.94, that part is no problem.
We will be shooting the commercial with a GH4 and recording the audio dialogue on an NTG-3 into an MM1 pre amp and into a Tascam DR60.
It is the audio requirements on this sheet that has me all confused. I usually mix everything in Adobe Audition and then export as a final track which which is then the only track that accompanies the video. I don't have any experience mixing 5.1 tracks and am not sure if this is something I should spend time learning.
When you look at the requirements above, do you think I can just submit the commercial with a stereo mix or do most places require a 5.1 mix as well?
Also, not sure what audio metadata stations usually ask for. Do they just want to know if it is 48 or 44 khz or is there someting else they may be looking for?
Thanks in advance!
Derek
Thanks in advance!
Derek
