delivering flash movie to web designer
I’m just getting started in Flash using CS3. For this project I just need to encode a couple of different video clips using flash and deliver them to my web designer.
I encoded my video clip to an .FLV file. Opened a new action script project and imported the movie onto the stage, adding a skin for playback and mute.
I tested the movie and it plays fine…audio and video. I exported the movie.
I now need to deliver this to my web designer.
I’ve tried a couple of different approaches: 1. I copied the flv file, the skin and the .swf files to a portable hard drive. It doesn’t play back.
2. I decided the link to the video file was the problem so I rebuilt the project all on the external portable hard drive so the link to the movie would point to the movie on the portable hard drive. I then disconnected my main video hard drive with just the portable connected and the file plays just fine.
I then tried to play the file on another computer and it doesn’t work. On one computer with FC studio 2 installed it trys to open the .swf file in live type. On another the icons are different than what I have on my original machine and it says it an action flash movie and won’t play either.
I have another computer with CS 3 photoshop installed and it plays fine on that one.
I presume I’m missing some important component or components I nthe file I want to deliver.
Can someone lease help. It seems like this should be pretty simple, but it certainly is way to much for this pea brain.
Thx…jw
let the web guy pick out his own flash player... just give him an flv... he can also put the flv on your webpage with no player, just code it to call up the adobe player... putting swf files on a website means a bigger download.
all that you need to test the flv on your end is the proper media player, here is a good freebie:
http://www.martijndevisser.com/blog/flv-player/
edit: that's for a pc, if you are on a mac, will qt play flv files?
