Dedolight Felloni: unsure which LED Felloni to get
A while back I was advised to get Dedoligth Felloni instead of the much more expensive Litepanels in terms of an LED kit.
I currently have a single Litepanels 1x1 flood. If I were to go for a Dedolight Felloni three light kit, which type of Felloni should I get?
Dedolight Felloni's come in 15, 30, and 50 degree angle LED 1x1s as well as bi-color and bi-focal.
Which angle is best for which type of situation? When would you use a 50 degree Felloni, a 30 degree, and 15 degree?
Is bi-focal and bi-color crucial?
And the Dedolight Felloni also comes in High, Standard, and Low Profile power intensity.
When would you use High? When Standard? When Low profile?
Thanks in advance for any advice.
Thanks for replying. Sounds like the high output gives you nearly twice the light output of the standard, am I right?
Would there be any reason to get the 30 degree angle Felloni? Or can the 50 degree Felloni be used as a keylight as well?
Hows your experience with the Dedoligth Felloni? I'm contemplating on purchasing the Cinesoft LEd Luminaries. One good feature I like is the color temperature adjustment. But I'm still open to shopping around for other LED lights, and seeing what is out there that can me an alternative. Hows the color temperature on the Dedoligth Felloni?
Spot on. There is one knob in the back for adjusting both intensity and color temp. You adjust one, push the knob, and adjust the other.
