decent gh4 shotgun microphone?
I would opt for one of the Rode mics designed for DSLR's, at least that is a "decent" mic company.
Any mic going into a DSLR is going to be limited by the quality of the audio section of that still camera. And any camera mounted mic is going to be at a severe disadvantage to one that is properly placed in almost all cases.
So camera mounting an inexpensive mic and recording to a DSLR is a pretty compromised workflow. Straight up talking heads interviews are probably OK but a narrative shoot is going to be very problematic. With all the above in mind It's still probably a good idea to get one since the built in mic is near useless. But keep in mind that if your doing a narative shoot you will want a separate sound set up and this mic will really be so you have a decent guide track to sync your "good" recordings to.
Yes, Azden gear is not highly regarded amongst pro audio folks.
That said, a cheap properly placed mic will sound better than an expensive improperly placed one.. and atop a camera is about the worst place.. but generally can be OK for B-roll and such.. But whatever mic you use, DSLR's still don't sound very good.
Yeah I used to have rode vmp but sold it while back , wish i didnt. Im not filming any narratives or storys or anything like that at all, mostly jus skateboarding, some car rally ect. I guess between Rode, Azden, and the Audio Tech. or Beyerdynamic mic. Just dont want to spend a whole lot on one right at his moment. I also plan on getting the Riggy Micro222 for my Cage / Mic that i end up getting.
I have the varavon cage, so your saying mouting the mic to top handle would be bad idea? Im not tryin to shoot a whole movie to go on big screen or anything just small documentaries and personal stuff.
Thanks for advice.
so your saying mounting the mic to top handle would be bad idea?
I was referring to narrative work. In your case, whatever's convenient, out of frame and quiet. (i.e. handling, servo, motor noise , ect. In some instances, (performances) a stand mounted mic is preferred. (sound is unaffected by camera panning)
