I am debating on which a slider to get. The two I have chosen are the Dana Dolly and the Shuttle Pod. And here are the reasons why:
DANA DOLLY:
-Cheap
-Rails can be purchased anywhere very cheaply
-Can be mounted on Low Riser Combo Stands instead of tripod legs
-Weight capacity
Cons:
-If I want a very long track (6ft+) transporting the pipes seems impossible since they need to be solid pieces. (Unless if there is a way to connect several smaller pieces)
-I cannot mount my Kessler 100mm High Hat (If shooting straight forwards, Id need the camera as high as possible so I don't see the track below the camera)
SHUTTLE POD:
-Has underneath wheels to shoot on extreme angles and vertically
-Tracks are only 4' long and can be joined together to make long tracks
-I can mount my Kessler 100mm high hat
Cons:
-Expensive at $2,500
-Weight is limited to 35lbs (but its not that bad)
-Needs tripod legs instead of light stands
What do you guys think would be my best bet?
DANA DOLLY:
-Cheap
-Weight capacity
Cons:
SHUTTLE POD:
Cons:
