Davinci. How to copy and paste corrections? :S
Neutral
Hi all,
So I decided to take a leap and dive into Davinci for the first time since I want to get better with my grading. I'm grading my latest clients project on davinci resolve 10. I was sent a draft of the video and told to start color grading, and a week later I would get the final which has some minor changes. So I've already graded most of the video and now I have the final cut, and I can't for the life of me figure out how to get my grade onto the this new video. If you look at the screen shot below I'm trying to get the grade i did from the shots listed as A onto the new video (B).
Any help would be greatly appreciated!
Under the color menu you will find a MEMORIES selection. Save your grade to one of them. Highlight all the clips you want to apply it too and select the Load option to paste the grade.
Thank you so much, you're a life saver!
Is there any way getting around having to "chop" up the new video file all over again?
Also, is there any way to build your grade on adjustment layers of some sort in davinci? In After Effects I would grade on adjustment layers that way if something changed with the original video I can just put it under my layer's and keep working with the same grade. In Davinci I only see how you can grade on the actual footage.
DaVinci works with nodes instead of layers, so that would be a no. But you can turn each node off and on as suits your needs. Consult the DaVinci manual for more details.
OTOH, it's "non destructive". IOW, it doesn't actually make any changes to your original files. When you complete your work, you render out new media.
