Darker rendering with magic bullet
MatRich
Carbonite Member
I need help with magic bullet. When ever I do my color correction, it is exactly how I want it to be and then I render it and it looks completely different. Its darker and more saturated that the still image that I see of the unrendered video in FCP. What is causing this and how do I fix it?
Under Sequence Settings (cmd-0 after clicking in your sequence), then Video Processing, what are you set to render as? RGB could cause problems - Personally I leave it set to render all YUV material in High-precision YUV, to minimize issues. Past that, no idea - I haven't worked with Magic Bullet. Good luck, and let us know if you find something.
Also I have noticed that if I set White as the background in the canvas, then when canvas is paused, the image is darker than when playing. With Black background there's no issue. As mentioned above also check your settings there.
