yzmotoxer807
So I am designing and building my own rod support system. I will have renders of the Solidworks Drawings up when I am done with the design, however, I am stuck because I cant find this part. I am looking for the little "L-Knob" that I assume an allen cap screw is pressed into and allows you to turn the screw with the knob instead of using a wrench (but still show the hex for the wrench if you want to use it). It is on seemingly every rod support clamp ever made but I cannot find then anywhere. I have found something sorta close on McMaster but they are plastic, cheasy, and don't show the hex for if I want to use a wrench. HELP!!! Does anyone know? Dennis?
