Cut from one image and paste to another ?
Justin_Kirch
Runner Up.
working in photoshop and i did this yesterday, but i have two separate images that i need to work as one. i'm trying to cut from one image and paste to another but it won't allow me to do it. how do i do this?
I'm not sure what you are meaning. If you mean you want both images to be on one layer, put one on a new layer above the other, use a Layer Mask to isolate the part of that image you want to keep and then merge the layers.
Select the correct Layer and/or Image
Use the Marquee Tool to select the area you want
Select Control (C) opy
Goto the other Image / Layer
Select Control (V) Paste
thanks guys for the response. i don't know what the problem was, maybe my comp was being stupid, i was trying to copy stuff, but it wouldn't work. thanks again.
ok, so my problem is that i have two images, but both of these images are in separate windows.
how do i make both of these images into one window? i don't know if i can explain this any better.
also, i'm trying to resize a pic so it can fit into the other pic, but every time i paste (no matter if i resize it), it always blows up the pic i copied to it's original size! what am i doing wrong?
Either Merge or Flatten Layers
Goto Top and Select LAYER and then go to Bottom:
To resize
Press Ctrl T
(Holding Shift to keep Scale same)
or goto IMAGE and then Image Size.
(It'll get easier)
Your wise man is a badass. Thanks for the links. The image I was trying to do is now in the cafe in the photoshop thread. Check it out, hehe.
