macgregor
I just downloaded a trial of Premiere CS6 for PC and played a bit with the program. After applying some heavy grading (32bits RGB curves) the preview window shows posterized gradients. I did set up the sequence to maximum bit depth but still the preview shows posterized images. So this is bad.
Now when trying to export the footage I get the following (bit depth and render quality always set to max):
- if I render QT or AVI files in any format, the video shows posterization, no matter the codec (even 10bit uncompressed or blackmagic RGB 10bit)
- if I render AVI Uncompressed (not to confuse with AVI, from the drop down menu) the video looks fine. no posterization!
- if I render in any image file format sequence (dpx, tif, bmp, targa, even jpg!) the frames look fine too, no posterization
What´s going on here?
