CS5 Mac Rendering Issue
Petros Kolyvas
I'm cross-posting this from the Cow:
I'm having an odd issue rendering out a composition. An animator completed the project in her own studio. I received the project file and all the assets, opened the animation successfully in AE CS5 on a Mac Pro (she was using CS4 on Windows). It looks fine. I can preview it in real-time, scrub through it, etc. etc.
However, when I go to render/export it, I'm only getting one parts of certain layers from one of the pre-comps and nothing else. Pretty much only the elements created in After Effect and none of the assets (all of which are Illustrator files - or rather layers from a single illustrator file) are coming through in the render
The odd thing is that I can reload the assets and the composition looks fine in the viewer, I can scrub through it etc. etc, however as soon as I go to render it the assets (although they look present) disappear. Every time I reload the project file, I need to reload the assets, but they still won't render.
Even if I bring the assets in anew and replace each item in each pre-comp and comp, the issue remains. The animator thinks it's some lingering issue with the CS4 to CS5 conversion.
Thanks a million for taking the time to read this - any help would be greatly appreciated.
Try rendering with the "Continuos Rasterize" icon activated? is locate between the "Shy-Hide" and "Quality" icons at the left of the "Motion Blur" on the Timeline, is look like a sun, keep me inform
Cheers
Hi Xenogears... thanks so much for the response!
some strange stuff happens when I do that... a bunch of other images appear (tiny versions of the AI assets) all over the composition.
Figured it out. I had to disable the "Render Multiple Frames Simultaneously" option. Seems to be quite buggy this new 64-bit CS5 engine. Oh well. 5 minute render instead of 30 seconds. What can you do? At least it worked.
There's a known bug...
There's a known bug with non-continuously-rasterized Illustrator layers and Render Multiple Frames Simultaneously multiprocessing.
