cs3&Blackmagic Intensity
Not sure what you mean by "Because of bad export of cs3 .." but I use the Product and it is fanatastic.
Tell us more about the comment and expalin the issue .
i mean generally ,i hate the adobe's render stream.It is destroys the quality of the original footage and gives you a picture really sucks.uncomp.codec selection is an another issue which you can not play easilly..i thought this card can maybe save my life..?
If you are getting a loss of quality on rendering you are using the wrong settings.
I work natively in HD and it loses nothing (discernible) in my workflow process out to Broadcast TV
I work on Black Magic products since years (SD-Decklink, HD Extreme and Intensity) - got nothing but praise for them.
I do everything in lossless Black Magic HD Codec, sometimes even in JPEG Codec (when space is critical) but you can see the JPEG-artifacts if you look close (but still good for the average viewer with a TFT or Plasma TV Set) - lossless is yust that - lossless.
Frank
Well, you're not going to beat $250 for what the Intensity does, that's for sure. You may find yourself tweaking the Blackmagic presets before you get them right where you want them to be, and the stability isn't 100% -- but once you jump through the hoops, it's $250 well-spent.
We use Intensity Cards for all of our capture workstations. Our artists find it quick to use to capture game play and turn that footage around for reference material.
You will need a Multi Drive RAID to do the un-compressed capture. I'm going to guess the lowest price for HD Uncompressed capture drive space (that's fast enough) will run you around $1,000 and that's assuming you know how to build it yourself.
