roblutz
Ok - first, I apologize if this has been addressed recently - I have checked the forum and scoured google with no luck but I may have overlooked sources as I'm sure this is a common issue.
So I have a 30 minute project in Premiere.
The footage was shot with a Canon GL-2 in the 24 frame cine mode. The video files differ in their frame rates in the project:
23.976 for the videos I worked on in AE and exported.
29.97 for the raw footage
and 2 files in the mix that are 24.00, and 30.00.
My project settings are:
Editing Mode: DV 24p
Timebase: 23.976 fps
720 x 480
Pixel aspect: D1/DV NTSC Widescreen 16:9 (1.2)
Fields: No Fields (Progressive)
Display format: 24 fps Timecode
So obviously there is quite a bit of inconsistency in my project due to ignorance going into it. I am having issues with my export settings now - what I'd like is a clean, uncompressed 24p version that I can load into AE CS4 on another computer to do the color correction and final export.
Right now im exporting as:
DV AVI
DV (24p Advanced)
Frame Rate: 23.976 fps
Pixel Aspect ratio: D1/DV NTSC Widescreen 16:9 (1.2)
Keyframe and Rendering
_______________________
Fields: No fields (progressive)
Checked Deinterlace Video Footage
Checked Optimize Stills
So with these settings I am getting a very lagged looking video with ghost frames and interlacing. As a side note I tried a square pixel aspect ratio export and got the same thing but with a green distorted line at the bottom of the frame of some shots.
I am dealing with a deadline for this and I've just run out of ideas. I have read some solutions to conforming video using Interpret footage and changing the frame rate / pixel aspect ratio in there but I don't want to start messing with that if it will affect the video files themselves. If anyone can offer advice, solutions, or just point me in the direction of some information i'd be really grateful!
720 x 480
DV AVI
DV (24p Advanced)
