MarkyMarkV
Hey DVX forums,
I was wondering if you guys could critique the lighting from a few screen caps of my short film. Please, don't go easy, but keep in mind I'm micro/no-budget and have little actual experience lighting, just tutorials/videos I've watched. This is my first project I've used lighting on.
Left: Raw image
Right: Color Curved/Corrected
Setup: 2 clamp lights, 1 camera left and and above the actors. I used either a Neutral Density gel or CTB. I don't remember which but I think it was ND. The other was a floodlight in a clamp-light reflective hood bounced off the ceiling for fill.
Scene: Couple watching TV late @ night.
Gripes: The only problem I have with this shot is that the shadows cast by the actors onto the wall are too heavy. I probably should've used a diffuser, but refrained from doing so out of fear of melting it (again.)
Left: Raw Image
Setup: 2 clamp lights. 1 clamped off-camera to the bookshelf w/ diffusion. The other was clamped directly in front of the actress w/ CTB. I ran that 1 through a DIY dimmer switch and turned it down to about 30-40%.
Scene: Teenage girl doing her homework & talking to her boyfriend late at night.
Gripes: My DIY Boom pole in the background...no one told me it was there, but that is largely my fault. I can work some After Effects magic to remove it, but I'm not sure if I'll end up using this footage anyway. I am the most proud of this shot because to me, the lighting setup doesn't look out-of-place; it looks exactly like what you'd expect for lighting in a teenager's room, dark, slight shadows, one light source, etc.
Left: Raw Image
Setup: 2 clamp lights. Both lights are in the same positions as the lights described above, however the CTB light is redirected and turned up slightly.
Scene: Jessica confides in her friend about her relationship troubles.
Gripes: The edge of the light is visible at the right of the frame, but it reminds me of a vignette. Is it possible to use light as a natural vignette instead of adding one in post?
Left: Raw Image
Setup: Same as the previous screen-cap.
Scene: CU of Jessica.
Gripes: None that I can think of for this one.
Left: Raw Image
Setup: I had to rearrange the diffused light source and move it camera right, as you can see by the highlight in the door's wood. I left the CTB light in place and turned it up to fill in the shadows a little bit.
Scene: Reverse of the previous OTS.
Gripes: Highlight in the door bothers me a bit, as does the reflection in the TV. My first Color-Correction is a bit too green when compared to the bluer tint of the previous pictures. I'll have to re-adjust that.
I know this is long, but I want some professional/experienced input on these shots. We've only shot 25% of this short film. A lot more night-scenes to come, which I'll probably have to fake during the day.
Album for High Res Pictures.
Left: Raw image
Left: Raw Image
Left: Raw Image
Left: Raw Image
Left: Raw Image
