I have heard this works, cant test right now and would like to see if anyone knows before I spend more time on it. Apparently some folks say you can get better hd on youtube by creating a slightly larger than hd file (2048x1152 is the example I’ve seen used). This triggers youtube to stream it at a higher bitrate than it does with actual hd material. However I am not sure it still works and believe I read it can create a worse experience for the viewer for some reason (bitrate too high for many viewers or something). Anyone tried this with success?
