HELP!!
I have been commissioned to shoot promotional video clips, some of which will be uploaded to social networking sites, (which isn't a problem), and some which is to be uploaded to the clients WEB site. The wed designer has asked for this footage in the form of FLASH, FLV format, and here IS the problem! I edit using Videostudio X2 Pro, which CAN render edited .M2T files in FLV format. However, because I am shooting in HDV, I do not know whether I can PRODUCE HD Flash clips using this method. Furthermore, I do not know the resolution to select for the produced files. I can choose from default settings in the FLV create section of 320 X 240 OR 640 X 480. However, this clearly isn't HD, and although I do have an alternative CUSTOM facility where I can enter the resolution size of 1280 X 720, I am not sure that this will work!! It may be better to use some kind of OTHER converter to change the original MPEG 2 to FLV. Advice desperately needed!!
Thank you,
Spud
Thank you,
Spud
