creating avi's and vegas settings
Sober
After a few aborted attempts, Im finally ready to knuckle down and try and re-edit Superman II! But once again I have reached an obstacle before I have even begun!
One of the great things about Sony Vegas is the ability to retain a 5.1 soundtrack - a neccesity for me.
Anyway, I have extracted the footage from the DVD using DVD Decryptor and its left me with the AC3 audio and the M2V Video.
Now here comes the science bit...
When I come to create the AVI in TMPGENC, it shows my intended avi file as having an FPS of 29.97 and I set the video mode as 'interlaced'. But before I began transferring 31 m2v files to AVI I figured I better make 100% sure what I was doing was indeed correct.
So I loaded up the M2V File within DGIndex to see its properties.
Lo and behold it came up with the following:
Video Mode: Progressive
FPS - 23.976
Now I may be stating the obvious here but I need 100% clarifcation...does this mean that I need to create the avi using these settings? I would imagine that if I use 29fps, the audio will be out of synch.
I would be very grateful if someone could confirm this for me though...do I use these settings within TMPGENC and VEGAS when doing my project?
If you pulled it from the DVD, it was on disc as 23.976. No audio issues.
You do realize if you post it anywhere, you're violating copyright, yes?
Many thanks for your help. I know lots of people probably say this but this is intended for my own use only.
As a kid I loved Superman II but when I heard about all the stories off set and how the director was fired it really tarnished my view of the theatrical film.
Then when I saw the Richard Donner edit I wasnt all that impressed either.
But somewhere in between a classic film is there and so because I cant bring myself to watch either. Im going to create my own so I can enjoy Superman II just like I did when I was younger.
