Confession 1: At heart I'm a doItYourSelfer and in fact used to build yacht hardware. Though at this point, I'd rather avoid re-inventing the wheel. For the time involved, I'm usually better off buying if it is available.
Confession 2: I'm an unsteady crane operator.
I am the proud owner of a Kessler Crane and while I don't use it too much, it's a nice piece of kit to have. I would use it more, especially with the shortest tip, if it was a bit more stable starting and finishing movement. There is (for me) an annoying vertical bump at the end of most every movement. This isn't terrible, but it is enough for me to think about improving it.
Question: Has anyone ever added a gas-strut shock absorber to a smaller (prosumer) crane like the Kessler? Any thoughts on this would be appreciated.
I also intend to improve the brake which is IMHO pretty lame and is the cause of a slight vertical bump even when using the crane for horizontal moves. But this is more straightforward than adding struts.
Edit: I might have said this a bit more clearly. The brake is just a bit weak in the knees and needs some increase in the thickness of the strut.
If anyone from Kessler monitors this thread, please speak up.
TIA
Grant
TIA
Grant
