qazwsx
I have a 50 minute WAV file recorded to an 32GB SD Card via a Tascam DR-70D (16bit, two channels, 48khz).
I've copied the file over to several locations, but When I play it back it's very choppy, like there's 1 second of silence inserted after 1 second of audio and going back and forth like that through the whole file. Within those gaps, there's no audio missing, it's literally like there is silience inserted and it pushes the audio forward, so if you take out those gaps, you will hear uninterrupted sentences.
However, while the clip is 50 minutes, and we recorded 50 minutes of audio, if you remove the blank spots there would then really only be 25minutes of audio recorded, the rest is blank.
Does anyone know if the full audio clip is recoverable? Or how something like this could've happened?
We previously successfully recorded 2.5 hours of audio on the same recorder. The only thing that changed was swapping the SD card, but that SD card was previously being used to record AVCHD video. Could that have caused it?
Thank you for any help
