Inprogress
I need to upgrade my laptop (either desktop or laptop - which ever works out better this side) from my Intel Core Duo T2300 1.6Ghz with stupid integrated graphics card (945GM something) cause I'm getting dejected with my editing which isn't happening due to old hardware.
However, budget is very tight - won't go into specifics cause I live in South Africa, however I do need some specific hardware advice.
Firstly, I do not intend to edit in HD, it'll be nice but I just do not have the budget for it. I'll also be using Adobe Premiere Elements (probably 10 cause locally there is a good deal on it supposedly - plus even 11 is affordable and gives me color grading options). I'll also start to experiment with some visual effects but mostly, for the lack of a better description, turn-key effects within software, not make my own, not yet anyway.
However, the three things I'm unclear on is the CPU, RAM and how the CPU affects graphics card choice.
I'll be going for 4Gig at the least.
So, Core i3 and up RAM and Graphics?
or...
Core i5 and higher RAM and lower graphics?
In other words, which is more important? Better CPU and good GPU with as much RAM as you can afford? Or OK CPU, better GPU and as much RAM as you can afford?
Most posts and advice I've research all come from the HD editing side it seems...it seems. Ultimately I suppose any low level, dedicated GPU will be better than my current setup.
Oh, and Windows 7....which one? Ultimate is best cause its Ultimate, but which one is good enough - keep in mind "tight budget".
I shoot with a GH2 however I intend to transcode since I create proxy clips, thus I can transcode to an "easier" codec, however I'll probably need to up my storage space then.
I thank thee all for thy kind wisdom and hope to repay said favor in future by means of kindness onto my fellow man
rogar-Happy(DBG):
EDIT: P.S. I'm open to AMD as well, have always liked them but please no arguments about which is better, I'm just looking for good enough in a tight budget.
Researching some local deals brings this question, an onboard ATI graphics card, waste of time compared to the onboard Intel setups?
For example I found a Open Box deal for this:
or...
- AMD A6 3420m QUAD CORE APU 2.4GHZ TurboCore
- 4GB DDR3 RAM
- True-to-Life RADEON HD6520G with Up to 3GB HyperMemory
- Windows 7 Home Basic 64 Bit
- 15.6" HD LED
- Lenovo
- 4GB DDR3 RAM
- 15.6" HD LED
- Lenovo
