Copy from P2 to USB HD? How?
petelms
Hi.
Someone mentioned that, you can copy from P2 card straight to USB HD also...Please, could someone tell me how to do this? I couldn't find any info in the manual...
Thanks.
you can do it to a firewire(1394) drive. Just set the camera in 1394 Host mode, then do that little thing where you hold down the button on the back to put the cam into the mode. There's a much better description in Barry's book, if you have that.
I also read somewhere that you can use a USB "on the go" drive the same way, because it has a controller built in to it. In which case you would not need a PC, but I don't have one and don't know how to do it.
Yeah, this is what I was after...how to use USB "on the go" to copy P2 cards on the field...
For USB-OTG, just go to the "other functions" menu and put the "PC MODE" setting to "USB DEVICE".
Then switch to PC mode.
Then plug in your USB-OTG drive, and press its button, and it'll automatically copy off the contents of the HVX's cards.
I'm sure that this probably works...unfortunately I have never been able to make it happen. And I've tried it many many times. I can however make it happen with the OTG firewire drive and 1394 host mode.
For a USB solution, I use these all of the time. These have a rechargable battery pack inside of them.
http://www.mwave.com/mwave/viewspec.hmx?scriteria=AA30310
For around $130 you get the enclosure AND 100gig drive. Like Barry said, its very simple. Firewire enclosures are scare and not that much faster on the transfer times. This is a great solution if you do not want to have a laptop.
I use these all of the time and GIVE them to my client.
