copy fade settings from event to another?
mthorsen
how do I copy the fade settings from a event to another?
I made a fade in and fade out which I would like to paste into another events
Re: copy fade settings from event to another?
I'm sure there is another way to do this... but this way works as well.
Go to your transitions window and drop a cross disolve transition onto your event. It will pop up a window with the settings. I was able to change the settings to just a regular cross fade and save it as "test-fade"
I'm sure then that you should be able to create your own fades using that method.
Hope that helps.
Are you trying to apply an effect, or are you talking about the fade duration or curve?
Gary
[quote author=Gary_Kleiner link=board=Vegas;num=1107993358;start=0#2 date=02/09/05 at 20:38:21]Are you trying to apply an effect, or are you talking about the fade duration or curve?
Gary[/quote]
i made a fade-in and a fade-out on a event on the timeline using the tool called envelope cursor. it shows when you place your mouse in the start or at the end of a event and now i simply want to copy the fade-in and fade-out and paste the settings into another event of similar lenght.
Sorry, you cannot copy and paste fade duration.
In Excalibur, a plugin for Vegas, you can set up fades (in/out/or both) that you can apply with one click.
Gary
