Cooling a threadripper workstation?
firehawk
Hi guys. I'm getting a new workstation to speed up my 3ds Max renders. I am getting mixed input on cooling for it. It will be running for days straight rendering (maybe weeks) so I certainly don't want heat issues.
The builder says the cooler it comes with is plenty to render 24/7 no problem. But some others say the cooler is not near enough, too small, doesn't cover the entire chip etc.
It will NOT be overclocked. I will install 128GB 3200MHz RAM when it arrives. According to the CyberpowerPC builder site it's the only cooler on the list that will fit the case but according to the specs on the case website, all sorts of large coolers will fit the case, top and front even.
http://www.phanteks.com/Enthoo-Luxe-TemperedGlass.html
This is a lot of money for me so I don't want to make a costly mistake.
My specs:
CAS: Phanteks Enthoo Luxe Full Tower Gaming Case W/ Full-size Tempered Glass Panel Window + RGB 10 Color LED Light Strip (Anthracite Gray)
CD: LG 16X Internal Blu-ray Burner, BD-RE, 3D Playback DVD+RW Combo Drive (Black Color)
CPU: AMD Ryzen™ Threadripper 3970X 3.7GHz [4.5GHz Turbo] 32Core 64Threads 144MB L3 Cache 280W Processor
CS_FAN: 3X 120mm Thermaltake Riing 12 Series High Static Pressure 120mm Case/Radiator Fan [+39] (Blue Color LED)
FAN: Asetek 570LC 120mm (Fatboy) Liquid CPU Cooling System w/ Copper Cold Plate (2x CyberPowerPC 120mm Dual Light Loop ARGB 1200RPM Fans w/ Hub + Remote (Push-Pull) [+16])
HDD: 1TB SAMSUNG 970 EVO Plus PCIe NVMe M.2 SSD - Seq R/W: Up to 3500/3300 MB/s, Rnd R/W up to 600/550k [+137] (Single Drive)
HDD2: 1TB WD Blue Series SATA-III 6 GB/s SSD - Seq R/W: Up to 545/525 MB/s, Rnd R/W up to 100/80k [+6] (Single Drive)
MEMORY: 16GB (8GBx2) DDR4/3200MHz Dual Channel Memory [-64] (Performance Memory by Major Brands)
I will swap it out with 128GB 4X32GB when it arrives 3200MHz
MOTHERBOARD: ASUS Prime TRX40-Pro ATX w/ RGB, Intel LAN, 3 PCIe x16, 1 PCIe x1, 8 SATA3, 3 M.2 SATA/PCIe [+51]
VIDEO: GeForce RTX™ 2080 Ti 11GB GDDR6 (Turing) [VR Ready] (Single Card)
