Converting a 23.98 project to 60i (29.97) for broadcast? Keeping 24p look?
Lkorver
I'm editing a doc in FCP at 23.98 (ProRes 422 1920X1080) The DVD duplicator and broadcaster want the deliverable QT file at 60i (ProRes). I'm assuming I can do this in Compressor and have found a good tutorial by Shane Ross, but I'd love to know if anyone has any direct experience with this?
- Should I create a 60i timeline and export from there first or just go straight from the 23.98 timeline to compressor to create the 60i QT file?
- Will there be dropped frame issues? I did a quick test bringin in 23.98 footage into a 60i timeline and there are now 1 frame gaps between some of the edits which tells me its dropping frames??
- I want to preserve the 24p look, is there anything I can do to preserve that? I've read the 2224 setting is best, but also heard 3:2 is best?
Shane Ross Tutorial:
23.98 to 29.97 via Compressor:
1. Drop clips you want to convert into Compressor
2. In Compressor, select your video then right click and choose NEW TARGET WITH SETTING > APPLE > FORMATS > QUICKTIME > APPLE PRORES 422 (HQ). Or pick whatever codec you like to work with.
3. Click on that newly created compression setting to open it in the Inspector window. Click the Encoder tab. Click the Video: (Settings…) button. Make the frame rate 29.97. Check the interlaced box. Set it's drop down menu to Bottom field first. Click OK.
4. Click the Frame Controls tab. Set Frame Controls to On. Set Output Fields to Bottom first. Leave Deinterlace on Fast. Leave Adaptive Details checked. Leave Rate Conversion set to Fast. Leave the Set Duration to: on 100% and make sure it's radio button is selected and NOT the "so source frames play at 29.97 fps" button.
5. Make changes to the Filters or Geometry sections as needed. Those settings listed above are the ones critical to getting the proper 3:2 pulldown added.
6. Submit the compression, then bring the resulting video back into Final Cut Pro. Place it in a 29.97 timeline and make sure you watch it on an NTSC monitor to verify that it looks good. If you step through it frame-by-frame you should see the familiar pattern of 2 split/interlaced frames followed by 3 whole frames. This is a very important step. I tried many solutions that looked OK playing back on the computer monitor, but looked terrible on the NTSC monitor.
You do not want 2224 as it the additional full frame (also known as 4+1) is very obvious to the eye in scenes with motion. FCP defaults to this as it is the least compute intensive for realtime play out over hardware I/O. All you're really looking to do is add 2:3 pulldown to emulate the same process a film to tape transfer uses, etc. You can even do this in After Effects.
Michael
I would export a master copy (uncompressed, perhaps) at 23.98, and then use the master copy to convert to 60i for broadcast.
This will lock in the 24 fps motion cadence of anything you've added, like fades, transitions, text, etc., so that they don't render as 60 instead of 24 and look strange with your footage.
