The problem is the following: A colleague has edited a 30min. docu feature in a 4:3 sequence because it is going to be on air that way. The source material is 16:9 anamorphotic from MiniDV tape and has been captured correctly (capture files are 16:9 anamorphotic when viewed with quicktime player).
Now I was trying to convert the edited sequence back to anamorphotic 16:9 to get full quality DVD copies, and not just letterboxed 4:3 DVDs.
However, when I copy the timeline to a 16:9 sequence, or change the sequence settings to anamorphotic, then FCP handles the material like letterboxed 4:3 and squeezes it down.
Is there any chance to get the edited sequence back to its original 16:9 anamorphotic format? The source capture clips are, as I said before, definitely 16:9 anamorphotic, so it should be possible, at least in theory
The version of FCP is 4.5 HD (a little dated, I know...) and we're talking PAL, but that shouldn't make a difference, I guess.
By the way it's not an option to edit the whole thing again... it's 30 minutes long and there has already been going a lot of work into it.
