ripupthehwy
Whats the best way to do this? I'm running premiere 5.5.0. I have an HD project (AVCHD 1080p/ 23.976fps
I want to record it to DV (DVCPRO) Tape for Television Broadcast, which means it has to be 720, 60i. (DV). Everything I do looks horrible, studdery, bad aliasing, jaggie edges. I thought Premiere did the 3:2 pulldown automatically (In Sequence Settings/Playback Settings is a "24p Conversion Method" window, I chose Interlaced Frame 2:2:3:2 option.) I made a new sequence with theses settings as a DV project (I tried both as a interlaced and as a progressive project and same results).
What about Adobe Media Encoder? Is there a way to just simply export the original HD file and convert it as an interlaced DV file with proper pulldown?
I have done all this successfully in Grass Valley Edius but there doesn't seem to be a pulldown option in Adobe Media Encoder.
Thanks for any help.!!!
EDIT: Okay, the best option seems to be exporting straight from the HD (1080p/23.976) project timeline and choose NTSC DV. Then taking that file and putting it on an SD timeline. It's not perfect but far better than placing the HD files on an SD timeline and printing to tape without exporting.
