convert Wide project to Standard?
FiddlerMD
I started a project as wide and captured a bunch of data off the dvx (footage was shot at 4x3). I was intending to resize to widescreen and edited some stuff already. now i'm thinking i want to stick with 4x3 after all - is there an easy way to just convert the project w/o losing my edit data?
thanks
Open a new 4x3 project...import your old widescreen project. You can resize and make any adjustments you need in the new timeline.
-Kevin
will importing the project import the sequences with all edit data? wouldnt that imported sequence be in 16x9 ?
When you import the widescreen project, you can drag the old widescreen sequence into your new timeline, or double click the sequence to open up all the individual clips. If you've already resized your footage, just shrink the scale back to 100%. Now you will be back to 4x3. It would probably be easier to drag the whole sequence into the 4x3 timeline and resize all the clips at once.
-Kevin
