I want to convert these timelapse files into wmvs so I can edit in Premier Pro. I can play them back in wmv translator, but not import them. Any thoughts? Thanks in advance
In case anyone is interested, I've had success converting these TLV files into AVI. I simply copied each file Adobe Bridge (PhotoShop), typed .AVI after the name and imported into Premiere. Now I need to see if I can mix in the timeline the older wmv files and avi ones, maybe I will have to convert the wmv into avi to edit the sequence.
Set the timeline to whatever format you want to render out, then just slap that stuff up there . . . unless they're corrupted they (pretty much anything now days) should play just fine if you're using a current version of PP.
